Did you check the fuse on the front of the right shock tower?
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
There are no strangers here, only friends you haven't met.
ok you can run 12Vs from the battary and that will tell you if its bad you want to jump the is not in the gastank right do that and that should tell you right away and its easy
When you turn the ignition to ON the fuel pump will run for only 3 seconds then stop.
Make sure you aren't getting fooled, it won't run all the time.
Until the oil pressure switch kicks in.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 12-19-2000).]
