1 - 10 of 10 Posts
well i was almost out of gas so i ran to the gas station to fill it up...car started just fine went to leave and after i shifted from first gear to second the car started to shake i had the pedal all the way to the floor it was acting like it wasnt getting any fuel...finally the car stalled i went to restart it it turned over n stayed started for about 30 seconds then died out again. i dont have much money to take it to a mechanic if any one has any ideas of where to start it would be alot of help:confused:
Has the car been sitting for a while.Have you ever changed the fuel filter.I sounds like it may be the fuel pump.Are there any fuzes blown if the pump is clogged it may have burnt up the fuze may have blown to tell you its the pump.If blown put a new fuze in if it blows again you will need a pump.What have you tried to do...Do you know if the pump is in the tank if it is get some one to try and start it while you bang on the tank with a block of wood.This is all I got some one here should know more than me.
First thing I suggest is to buy a manual for the car from your local auto parts store, a Haynes manual. The manual has alot of useful info for maintaining the car and for troubleshooting the problems arising.
I would listen for a 'buzz' for about 2-3 seconds by the driver side rear wheel when ign key goes from off to IGN. This buzz signifies the fuel pump is working as commanded by the ECM.
If you ran the tank to empty, and the engine died later after adding fuel, I would change the fuel filter back by the tank.
You can do a simple check of seeing fuel pressure by looking on the fuel rail for a tire valve, commonly called a Schrader valve, looks exactly like a tire valve. Turn the ign key on, f/pump runs for 2-3 seconds. Protect your eyes and press on the little stem inside to see if gas comes out. No gas, no pump or no power to pump.
Don't run the tank to empty, never under 1/4 tank. The fuel in the tank cools the pump during operation. No fuel, pump can overheat.
Check other connections you see in the engine compartment. Make sure they are plugged in. Check the condition of the hoses in the engine compartment, replace any with cracks or crumble in your hand.
Welcome to the Club.
There is an easy way to hot-wire the fuel pump to run all the time (as a test) by jumpering two connections in the FP relay socket. A pressure gauge is nice - see if Autozone will loan you one if you don't have one.
Sounds like it's out of gas - you weren't clear if all the shaking started on your way to the gas station or after filling up. If it was after, you wouldn't be the first person to get bad gas. I know at least a half dozen people who got bad gas and their cars died within 2 or 3 minutes of starting it.
well it started after i filled up..water in the tank was my first thought so i poured a bottle of heet in it still wont start..me and my buddy checked to see if the pump was kicking on we both heard nothing
The fuel pump will run for just a second when the key is turned on. That's part of the ECM's boot up logic and it primes the pump. Beyond that, the ECM won't engage the pump until it receives pulses back from the distributor. What's weird is that everytime to flip the ignition switch on and off, the pump won't necessarily run. I'm not sure if the pump builds up pressure and stops cycling or if the ECM remembers that the pump has already been primed and doesn't turn it on again.
Don't rule out a bad FP relay. But really, you need to figure out how to jumper the FP relay, to get the pump running and verify if it really is an FP issue or perhaps bad fuel. No sense worrying about bad fuel if the FP won't run and make pressure.
Fuel pump relay is located on the firewall next to the drvr side hood hinge, a black box 1X2 inches.
You can unplug the relay and jumper across the two wires of the largest wire gauge. Use male quick disconnects and a heavy wire, say #12 AWG. With this jumper in place, you should hear the f/pump humming back by the drvr rear wheel and you can test pressure at the pressure valve on the fuel rail with a tire pressure gauge. Kind of shadetree, but it works. The pressure valve looks like a tire air valve.
Discussion Starter #9
thanks for your help i jumped the realay pump is fine...took a look at the distrubitor it was loose took it of and insepected closer magnet and pole needs looks really bad got the parts coming in wednesday.. :yes:
If the FP is running normally and creating pressure then one of two things is going on. Either the ignition module is not sending pulses to the ECM and thus the ECM is not engaging the pump. A fuel pressure guage would confirm this - if the pressure kicks up after you crank the engine then the ignition module is signaling the ECM.
The fact that this just started when you fueled up the car really makes me suspect bad fuel. I've known several folks who have had this happen. The theory is the fuel storage tank gets water in it (which normally settles to the bottom of the storage tank). Then the fuel man fills up the tank and agitates all the water. You pump gas into your car and get a tank full of bad fuel.
If you're lucky and the water isn't all that bad, you might get buy with a bottle or two of fuel treatment (containing methanol). But it may sputter and fart for quite some time until you burn off most of the water.
1 - 10 of 10 Posts
