1 - 2 of 2 Posts
New driver Camaro 1991 Conv. Power door locks do not work. I checked the fuses and could not fine a bad one any guess why it will not work.
Usually is the driver's door switch will corrode within. Replacement is needed. Same goes for pass side.
Go back to fuse and measure voltage on the two spots of the fuse on either side of the number stamped on the fuse. If no power for either terminal, then a fusible link at starter or battery is blown.
1 - 2 of 2 Posts
