I have a 1996 6cyl. The car will just go dead. No lights- no start. I touch the positive and neg poles of the battery and power returns - any ideas on where to start?
Sounds like a battery connection is getting knocked loose?? Give us some more info on your problem though!
The Battery posts are Tight, Clean and Shinny - Battery never goes dead - just the entire electrical system shuts down.
Also not throwing any error codes. Leads to alternator, plastic box and post on fender also cleaned. Any ideas where else to go?
i have a 1996 6cyl. The car will just go dead. No lights- no start. I touch the positive and neg poles of the battery and power returns - any ideas on where to start?
sounds like the battery itself is bad if thats all you do and the power comes back?? The posts are broke inside the battery??
...I touch the positive and neg poles of the battery and power returns...?
I hope you're not touching the positive and negative poles together :eek:
Sounds like a classic bad connection despite what new parts may be in there. My 2002 Z28 just went dead one day the moment I turned it off. No lights, no cranking - nothing. I went under the hood and measured between the battery (-) and chassis ground - turned on the key and saw nearly zero volts (good). I did the same test between the battery (+) and a large positive stud near an under-hood fuse panel. This time I saw anywhere from 2 to 6 volts (bad). I was loosing voltage in a bad connection.
Turned out the positive cable clamp had develped a bad connection (fall-out from a former leaky delco battery no doubt). I buffed up the clamp and reinstalled it and it's been working fine every since.
I've seen plenty of lead clamp cables develop a bad connection between the lead clamp and copper wire.
Best advice is to get a digital volt meter and find out where your 12V is getting lost. Using a voltage drop test like I described above, you should be able to verify the integrety of all the wiring and connections in the power circuit. It's either bad wiring or a bad battery.
