One day, the serpentine belt on my camaro went loose and fell off the compressor. I checked and the back bracket to the A/C Compressor was off. Meaning before the belt came off it was still not on. Since there was so much tension on the compressor, it broke the bolts that go into the block on the engine. I managed to get two of the broken bolts out. But it had two other one's I could not get out. I put the compressor back on with two bolts and the mounting bracket bolted to the engine on the back of the compressor. Again, it broke those bolts and now the compressor is loose. This is going to be a hassle having to take the compressor off again and take those bolts out. Even if I do manage to get the other bolts out, they will probably break again. And I can't get the old bolts out cuz I used titanium drill bits, extractors, etc. and NOTHING would get them out. Is there anyway to drill in new threading in the block. Because that block is STRONG and hard to drill through. What do you think I should do?
