We've been working on 2 separate things on the front for a bit. Started mocking up the intake tube and a plate to mount the oil tank on. Stephen helped with the cardboard template work for the plate but let me do the cutting. It's 16 gauge so pretty stiff but I'll still use a bead roller to add some rigidity to it. There's a place near by called 'The Manufactury' that has lots of sheet metal tools to use with a membership so I'll join that for a bit to use their bead roller and break and sheer when needed for some other work. Need to shorten the J leg of the intake about 2 inches to get the filter where I want it in the fender. It will get tig welded together once the pieces are cut and match marked correctly, and a MAF bung will get welded in the straight section too.
Work in progress, gives an idea of where we are headed though. The oil tank mounting plate will serve as a block off panel for the PS Fender too when finished with seals around the edges, kind of like the OEM AC block off panels to block air from going around the cooling stack
