I was driving my 2012 SS last weekend and while accelerating, the engine light came on, as did all the ABS and traction control lights. A Service Stabilitrac message also appeared in the VID.
I checked for codes and only had a P0300 - general engine misfire fault.
The car was running noticeably rougher. I checked the fuel pressure, vacuum and both were fine.
I did find zero compression in cylinder #3. I took it to the dealer and they indicated that I had a bad valve spring.
They replaced it, and it runs fine now.
