Could anyone let me know if originally a car(69 camaro) had a 3 speed manual and to change over to to a 4speed m22 would the shifter be in the same location of the tunnel or would it be futher back?
I had to remove about 2 inches of metal at the rear of the 3 speed hole in order for the Muncie shifter to be centered in the 4-speed shifter boot retaining ring while in neutral. The 3-speed hole is not rectangular like the 4-speed hole, so it won't be a perfect fit.
I used a '69 GM Hurst shifter. It may fit differently than the Hurst aftermarket version. It did not use the u-bolt.
