I am just wondering if the pullies and brackets off a 305 will fit on a 350? i have a complete 350 except the brakets and pullies and know a friend with an old 305. Also could I reuse all the bolts on the 350 when i rebuild it? (just clean them up and paint them)
Tom
Everything will work just fine...bolts, brackets, everything. Arent chevys great
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
I may be wrong on this, but I think the balancers are different. I think the one on the 350 is bigger. Just something to think about if you plan on using it.
Racer#00
Plain Jane 67
76 Trans Am Stock Car
74 Z28 (Basket case)
Discussion Starter · #4 ·
I will not need the balancer. just the pullies and the brackets (alternator etc.)Also is it a bad idea to reuse the bolts on the 350 when I put it back together? such has the bolts for the heads, intake etc.
Tom
Mixed opinions on the bolts. I hear it is bad to reuse them, and some say it is fine. I guess it boils down to how much torture is inside the combustion chamber. If you are running high compression/potent engine, then fork out a couple of bucks for some good new head bolts to keep the gaskets from blowing. Bolts are cheap, head gasket repair is not.
Brave man not milk bull... only stupid man
I've reused everything from a 305 on a 350, then reused it again on another 350 (including the balancer) and never had a problem. I guess it depends on your budget.
