I just bought a 67 camaro a few weeks ago. It has a small block 350. I don't plan on driving it til spring, should I start it or is it ok to sit for a few months? Thanks for any help.
Chad,
It wont hurt it to sit. It is actually worse to just start it and run it without driving it. Just make sure you charge the battery once in a while. Might also want to check the antifreeze if it gets cold enough to freeze in your area.
did you put gas additive in there. if not add it and run litlte bit. this new gas sucks. it goes away quickly and absorbs moisture. darn additives that they add now. fill tank and put in the additive so it doesnt get moisture in system.
