Hi guys,
I'm having trouble with my engine in my 69. It doesn't run smooth or even stay running especially when cold. I need to have the idle up to 1000 for it to stay running..
It is a 1971, 350 with I think a 2 bolt main. It has a Comp cam 12-423-8 276/282. Dur @.050 is 224/230. Lobe Sep 110. Lift 502/510. It's a hyd roller.
Alum intake (EPS) and alum heads (E210).
It has a Holly 630 vac secondary.
Tremec TKO600
Chevy HEI
So, What should my idle be?
What should the timing be?
Is this the correct carb for the set up?
Can I go bigger on the carb after I get it running correctly?
Hope someone can help, Thanks.
Tremec TKO600
Chevy HEI
