1 - 8 of 8 Posts
the code on my block is 3970010 which comes up as 350 or 327 how do i know the difference???
I'm not sure if this is right. The code that you gave us, doesn't seem right.
MA 1967 327 manual trans. 210 2 Camaro
Nope: the 3970010 's were not made until 1969
thanks 4 the help i rechecked #s back driver side reads 3970100 and front pass. behind alt. reads ma30800 but it has 4bbl
head reads 3998993
Info for the head casting:
1968-76 3998993 350 1.72 1.5 - truck
The block sounds like an over the counter replacement 350. I seem to recall running across the MA designation before. If it was an OE engine installed in a GM vehicle, the assembly stamp would be Vxxxxyy(y) or something similar, and there would be a partial VIN either on the pad or on the flange above the oil filter.
A check of the block date code should confirm it is not a 68 327, and the casting number off the crank would confirm. The bore is the same.
1 - 8 of 8 Posts
