Hello guys. Still new to turning wrentches but here it goes. I have a a 383 stroker with lunati roller cam and 200c aluminum Dart Shp heads. Just recently installed a holley sniper efi and had to replace my distributor. Setting my intial timing i set it at 12* deeg btdc on the compression stroke, distributor is pointed at the first cylinder and i begin to turn the key it just cranks over and over. I turn the distributor and still nothing. Any advice for a real beginner?
Ps. I am getting air, pulled the spark plugs see and smell gas, and saw spark on the wires when i was crank. Also looked at the little efi module and set up the wizard as seen on youtube. Thanks guys
