I am thinking about making 350 in 68 Camaro into 383 Stroker.
Will stock oil pan work?
No power steering......just stock stabilizer and factory 68 front suspention.
If stock won't work...what are you using for this application?
Thanks....Lane
I used my original pan from my 327.
Rick
If you are going with a igh volume pump, you will ikely want to get a larger than stock pan, so the oil pump does not run "dry"...
