Just bought a 68 rs/ss 396 4 speed.The engine is an L78, question is did the car come with one.The car doesn't appear to have ever had a fuel return line,the rear is 12 bolt.What else to look for?
First you need to get the number from the castng on the block. This will give you a start. There was no return fuel line on a BB. Look for the heater hoses going from the pump and manifold. the hoses should enter in the middle of the firewall casing. There are any ways to decifer your car. A camaro book would be the best bet. John Hooper puts out a good one. Hope this helps
Discussion Starter · #3 ·
Thanks Dino, heater hoses do go to middle of heater box,have to do some cleaning to be able to read numbers.Thanx again.
Lower horsepower BB motors did have 2 fuel lines in 1969. I don't know about 68s. 375 hp motors only had 1 fuel line.
Bob
Garnet Red 69/SS396/TH400/355 Posi
94 HD Dyna Wideglide
Discussion Starter · #5 ·
I appreciate the help, seems like the 68 is a little harder to figure out as the cowl tag doesn't have enough info.
