This is as popular as the high performance 305 stroker engine using the crank destined for a 383 in a 305 bloc. And this is for the same reason, the 396 bore is too small to even unshroud the stock valves, which also prevents any larger deeper valves from ever being used.
There are just to many stock 454 blocks around to consider using a 396 block for anything other than a numbers matching restoration. One of the reasons a 396 block is so rare now is that everyone who has had an option of using the bigger bore 427-454-502 blocks has turned their old 396 blocks into Kia's and Toyotas. Unless you have a '65 or '66 block it can not be safely bored out to 427 dimensions.
Don’t want to start a war or hurt anyones feelings, but that is the way it is in the "real world".
Larger Dave
Proud owner of a 4.600" bore 4.375" stroke standard deck BBC with 396 decals on it.
