Well its been a while since last post. For many reasons had I to scrap the 496, but good news is it forced me to build a 505 Stroker (454 2 bolt base).
Although I reused a lot of the same parts here is the new build sheet.
-AFR 290 Heads
-Custom Carrillo Pistons
-Forging 542
-Weight 585
-Dome 0.125
-Custom Cam
-Advertise 303/309
-Lift 643/60
-Sep 108
-Adv 5
-Stealth Manifold
-950CFM Quick Fuel Carb
-MSD Ignition
Engine was Dyno on a Stuska Depec W/ ADL load control
-605 TQ @ 4300
-568 HP @ 5400
-11.98 Air/Fuel
-Timing 36
All of that translated to 461 TQ and 423 HP on the chassis dyno (Don't know which Dyno Type)
Any comments/ thoughts /advice would be appreciated.
To note the original 496 measured on a Super Flow SF-8902, without the custom cam or pistons
-611 TQ @ 4400
-593 HP @ 5400
-13.6 Air/Fuel
-Timing 30
Have not yet driven the car yet, installing sub frame connectors and close ratio steering box. Should have it on the road next month when the weather breaks
25.52% parasitic loss through the drive train lets me guess you have a 4,200 RPM stall converter and a nine inch rear end.
The increase in initial timing over the 496 and the loss of horsepower indicates that this isn't a very efficient combination. I am of the opinion that your heads are a little on the small size for an engine with this displacement (I probably would have gone with the 315 cc CNC AFR head for this size motor; if I were buying new heads).
I am also assuming you increased the bore on your old 496 build as opposed to going to a longer stroke crank. The thinner cylinder bores also contribute to your horsepower drop as you are loosing more heat to the coolant (which will put a further strain on your cooling system). Cast iron is a lot worse at conducting heat compared to a metal like aluminum, but as you thin it down the then the heat can flow through it at a faster rate as the metal thickness decreases. It also becomes more flexible which will upset your ring seal.
My final comment is on the carburetor. A 4500 series carb makes a BBC a lot happier than the same size (cfm) 4150 series carb. People say you can not run a 4500 on the street (I did it for years), but I would point out that most cars built to this level are not considered daily drivers. I prefer the added performance over the look of originality with the smaller carb throats with a shinny open element air cleaner and a 396 decal on it.
Big Dave
Dave,
Thanks for the feedback, I appreciate it. I am actually running a dual disc Macleod back to a M22,12 bolt with 3:73s.
You are correct rebored with same crank and connecting rods. I get the heat issue just have a hard time believing its causing that large of a overall power loss given the blueprinted pistons and upgraded cam.
I also agree with the heads 290s are at the limit for the 505s and if I was buying new heads would have went with something a little larger. I also wondered it the 950 CFM was little under sized.
The other thing to note is that all 3 dynos (engine and chassis) were done by different people and different machines. Its a street car but might just have to take it t the strip to see what it can do.
Different dyno,s give different numbers so I would not worry about that. Only advice I can give is make sure your tires are up to the job, no sense having all that power to just burn rubber(although that is fun but expensive).
Dynos vary from each other (eddy or water brake), and the same dyno will yield different results on different days just due to changes in the weather. I only use a Dyno to tune as it offers easier access than leaning over the fender of a car at the track.
I don't really care what the ultimate number is as it is far too late once it is built to worry about it. I just take the info and add it to my note book which gives me direction for my next build (back then I was building a motor or two a week, so it was an ongoing learning experience). In retrospect, my memory was failing even twenty years ago which is why I wrote everything down (very important when you have to read what you wrote down were on different parts that are often fitted together a number of times). I caught an oil pump I thought from memory that I had torqued for final assembly; but my records indicated it had only been hand tightened (no record of being checked off on assembly build sheet with a torque value).
Big Dave
Im only 44 and have to keep records. I keep a notebook on carbs, jetting and engine size. I downloaded an engine assembly sheet. You have built WAY more engines than I have but things tend to get blurry when your trying to remember what you did months or years ago. My bracket engines are running 3 years.
