i bought a camaro with a 327 in it and the heads have a casting number that ends in 545 the have screw in studs with guide plates. they have a strange marking on the end of the heads it looks like two power pack points side by side. any ideas? thanks jerry
I have seen many different reports such as:
330545.....73......350..........76cc chamber, 2.02/1.60
330545 1973 350 76cc chamber 2.02/1.60
1971-75 330545 307,350 1.72 1.5001 74 cc
330545 1971-75 307/350 1.72 1.5 74 cc
The only agreement looks like big chamber smog head with any size valves.
Decent head if you blend the bowls and open the runners.....
Banned
NOT for a 327!!!
You will need to run 350hp/327 domed pistons to even begin to have any compression if they have big smog chambers, imho.
Now, I don't think so, but if by chance they are double-hump 68 cc chambered heads, then install them along w/ Fel-pro's #1094 shims and go! Should be around 9.5 to 1 CR'd...
pdq67
