Hi guys,
I bought the trickflow top end kit for my 69 camaro with a 350. Hopefully this year I will finally install it. I currently have a edlebrock 1406 600cfm carb on my engine now. I also have the calibration kit that goes with it. Originally I was just going to use that carb since that is what I had. However, my brother just gave me a edlebrock 1407 750 which has an electric choke installed. I'm in the process of rebuiding that carb. I know 650-670 cfm carb would be ideal, but since I have these two carbs, I'm gonna use either one. I don't have the calibration kit for the 1407, but if I decide to use it I would get it. Right now I'm not sure which of the two would be best for my combo.
Here are the cam specs
Lift
Intake @ cam 320 @valve 480
[email protected] cam 3294 @valve 494
ADv duration 284 Int 290 Exh
Dur @ .050 is 228 Int 234 exh
Springs 110 lbs closed 312 lbs open
1.50 ratio rocker
Cam timing opens closes
@0.004 Intake 32 BTDC 72 ABDC
Exhaust 75 BBDC 35 ATDC
Cam timing @ .050
Intake opens 8 BTDC closes 50 ABDC max lift 106
Exhaust opens 51 BBDC closes 3 ATDC max lift 114
The heads are Trickflow 195 with 62cc chambers however they are not cnc'd. I'm also using an edlebrock performer rpm manifold and trickflow 1.5 roller rockers. I have 1st design ST-10 4spd and 3.42 posi. This is for the street.
Lift
1.50 ratio rocker
Cam timing @ .050
