1 - 10 of 10 Posts
As far as I know a 6500 redline tach wasn't available in '69 Camaros. There was a 5000 redline 7000 tach in the SS 350's, a 5500 redline 7000 tach in the 325/350HP 396's, a 6000 redline 7000 tach in the 375HP 396's, And a 6000 redline 8000 tach in the Z28's. I have been wrong before.
'69 RS Camaro
355 5-speed 4.11
There were 3 different Tachometers used on 69 Z/28's. The early production cars got 6000 redline x 7000, the mid year production got 6000 x 8000, and the very late production got 6500 x 8000.
I thought I was wrong once, but I was mistaken
-Mark.
So what is GM's thinking on red line numbers? They change the red line from 6000 to 6500 and use the exact same driveline? I would think they would have the numbers calculated out a little better than that.
Just for the info. my LM1 350/255 RS has the 5000/7000 tach but I have no idea if its original either.
click
69RS 350/255 LM1,TH350,Dover White,Blue Vinyl top
F&R spoilers,pdb,ps,am/fm,3.08 Posi.,A/C,
fold down rear seat.
My RS www.brainerd.net/~knudsen/69RS
Redlines weren't set based on powertrain capability or power curves - they were set based on warranty expectations (which doesn't explain the very late-'69 Z/28 500-rpm redline increase); when marketing is involved, some things just "happen"
JohnZ
CRG
'69 Z28 Fathom Green
The 6500 rpm red line tach is found in a few very late production Z/28s.
The '69 body style was supposed to carry over into '70 with the LT1; plans changed. The '70 Z/28 tach is 6500 rpm I believe.
Just a routine engineering change.
1 - 10 of 10 Posts
