1 - 12 of 12 Posts
I have the canister type oil filter on my 67 327 using a WIX cartridge. I like it but I just put in a TH350 and the dust cover for tranny is against the canister not allowing it to bolt up on the top 2 bolts and I would prefer not to just have it bolted on with the bottom 2 bolts only.
I assume the spin on filter has less width so the cover should then fit as designed
Is the Fram K98ADP adapter what I need?
or this one?
https://www.summitracing.com/parts/...9V8qry4erZ04PyWvwss4OMLOTBxxXclwTUaArCm8P8HAQ
or?
What about bypass valve?
and what filter is then used, preferably WIX #?
I would slot the bolt holes on the dust cover to get it to fit like it is supposed to.
You only need a by-pass valve if you are running a high pressure oil pump with thick oil, or you never change your oil (which I would highly doubt in your case).
Both the Mr. Gasket Oil Filter Adapter Kit Part Number 1270, and the Fram K98ADP adapter are used as a direct replacement for your canister filter.
Modern blocks are machined inside the oil filter cavity flat to seal the spin on canister; but your block was not (it can be on a future rebuild to get rid of the O-ring gasket). Recommend it over an adapter such as this one:
https://www.danchuk.com/ItemForm.aspx?Item=16242
Which is an OEM spin on oil filter mount for a machined block made after 1969; as it would probably have a leak over time.
Big Dave
Big Dave
I don't have a HV pump nor do I use heavy weight oil. Use 10-30 and my OP is about 20psi at hot idle and 40+psi at cruise speed
So do I have a bypass valve stock with a canister filter set up? (thought I did)
Slotting or enlarging the top holes of dust cover won't resolve the fit issue. The canister body is not allowing the dust cover to go all the way up so the top holes to get up to the tranny case holes. Bottom holes line up but the cover is "deflected" as the canister is not allowing it to go all the way up
I had to do minimal trimming of the re-pop cover around the starter opening, no big deal. The top of cover is not hitting the block, it seems to be the canister is not allowing it to go all the way up (about 1/4" more). Since the TH350 never came with a 67 with canister filter I see why there is a conflict as spin on filters, IIRC, were for 68 and on.
I will try bending in a slight curve on the part of cover to see if that gives the clearance but need to make sure I don't bend it into the FW. I could also cut a slot in the cover but would prefer not to hack it to that extent
Swapping in parts (tranny) that didn't come with the car but is a "bolt in" does have a * as footnote. In this case..."some adjustments may need to be made on dust cover to fit"..
All of those kits are basically the same. Consist of an investment cast (permanent die) aluminum base, four screws, a machined adapter (similar to this one:
https://www.summitracing.com/parts/nal-3853870
and an O-ring as found in your canister oil filter replacement filter package.
Those components are all probably made over seas (which is fine except for the screws) and are sold by a number of companies.
Only issue is you have a double seal. The adapter plate, and on the spin on filter. You get a new gasket with every filter but the adapter plate O-ring stays in place getting hardened by age and will at some point fail.
Big Dave
Discussion Starter #9
Thanks Al....so you have any leak issues with the conversion?
some reviews note them....but online review negative often is "operator error" :)
Discussion Starter #11
Good to hear Al...WIX, to me, has always been A+ product
The adapter is as wide as Canister so I may need to notch the top of dust cover to clear that part but the spin on filter looks to be much thinner than canister so otherwise clearance to cover with spin on should be a non issue
You use the 51061 filter with it?
1 - 12 of 12 Posts
