The only part that will squeal like you describe is the throw out bearing. You can look at the rest of the parts after the trans is out
That’s what I think too.I think the synchros in the trans will move the rear wheels under no load. With that noise I bet the throw out bearing is destroyed.
The pilot bearing can make it squeal when the clutch is engaged also.The only part that will squeal like you describe is the throw out bearing. You can look at the rest of the parts after the trans is out
If I remember correctly you'll still need to get a pilot bushing. The one that comes ithe the clutch is magnetic. Your local parts store should be able to get you the Federal Mogul pilot bushing shown above. If they can't get the Federal Mogul bushing take a magnet to the store and check it before you buy it. I believe I purchased a National PB656HD and it was non magnetic from my local Oreilly Auto Parts store.Thanks guys. I ordered the McLeod clutch kit that you both recommended.
Copy that. Thanks!If I remember correctly you'll still need to get a pilot bushing. The one that comes ithe the clutch is magnetic. Your local parts store should be able to get you the Federal Mogul pilot bushing shown above. If they can't get the Federal Mogul bushing take a magnet to the store and check it before you buy it. I believe I purchased a National PB656HD and it was non magnetic from my local Oreilly Auto Parts store.
The old bushing can be a pain to get out of the crank. If it's a bushing vs a roller bearing I've had the best luck with the bread method. That is get a bolt that will just fit in the hole, stuff the hole with a bread, and then put the bolt in the hole and tap it with a 3lb hammer. Then add more bread and tap it again until it pushes the bushing out.
If it's a bearing you'll need a pilot bearing puller. You can rent one from the local parts store.
