1 - 10 of 10 Posts
Hey guys, back again needing help with some parts for my 67 RS 327, 210 hp, 2 barrel. Page 102 Aim, 3908966 divorced choke, 3840906 cover choke, page 105, 3908780 spring, 3904249 bracket. This 2 barrel stuff is hard to find. Thx Tom :confused:
Discussion Starter #2
Found 67 2 barrel divorced choke, cover, and spring. still need 3908780 bracket.:confused:
67 327 2 barrel, Accelerator Bracket, AIM page 105, GM part number 3904249. Thx Tom
My 67 2 barrel did not have a bracket for this. The coil mounting bracket had a hole drilled in it that the spring went into. I always assumed it was the factory setup. Had the car since 1980.
Hey Guys, I in boxed Al, his car has one. I have some pics he posted a while ago on another thread, check it out. Al is going to take some additional pics and post them. My mechanic's 327 2 barrel has the same bracket, he is the original owner. Tom, I tried Carb doctor and Mike's, no luck Thx.
Interesting. You can see the little hole in the coil bracket right above the adjustment screw head. Thats where my spring has always been connected to. It did touch the manifold a bit using this hole. I never had the little bracket. Btw, whats with the funky looking pcv valve?
Discussion Starter #9
Thx again Al for the pics... One think that I find very odd. There were 102,409, 327 2 barrels produced (LF7) in 1967. Why is it so hard to find parts for the 2 barrel setup. Everything being reproduced is for the 4 barrel 327's, 427's and 350's. Examples, divorced choke and cover, accelerator rod, SPRINGS, carb fittings, etc. When you call companies (Ricks, Classic, Heartbeat City, etc) they don't stock any of those items. Does anyone know where I can find the spring bracket pictured? Thx again Tom....
Discussion Starter #10
Hey guys, good news. Found the throttle return spring bracket. I installed it yesterday. Check out the pics. Thx for all your help.
1 - 10 of 10 Posts
