Does anyone know of a company that sells wilwood kits for a camaro but will do a custom kit for a 9 inch rear?
Thanks in advance
I checked the moser site. I am looking for the rears for the 9 inch with an e-brake and matching fronts. Also maybe a wilwood master cylinder.
Yeah, Moser does it. Ever since they changed their site things are hard to find. They build a 9 inch that is a direct bolt in for a first gen and make brakes for it as well as offer matching fronts. I would call them instead of buying them directly off the site. They need to know if you've got the Ford pattern or Chevy pattern on your axle ends and also if you're running original '67 location shocks or have moved to staggered shocks so they do the brackets and e-brakes correctly.
I would think that Matt's Classic Bowties or Prodigy Customs could take care of you as well.
Vendor
We do have the 9" Wilwood kits...There are a few to choose from. Take a look at Wilwood.com and give us a call if you need any help!
