Hello All,
I just got my new strange ford 9" rear end with 31 spline axles for my 67 Camaro. I put timken A20 bearings on both axles. I then mounted axles in the rear end to measure for some wilwood brakes. My options for brake kits had an axle offset of 2.32" 2.50". I measure my axle offset and they were about 2.65". I thought that was close enough for the brake kit and maybe I could slightly modify something in the future to get them to fit as I knew didn't have the 2.32" version. It turns out the brake kit requires it to be very close to 2.5" as I cannot fit the caliper over the rotor because the hub/rotor sticks out 0.15" too far (2.65" - 2.5"). My bearing is sticking out about an 1/8" which I read is normal so I thought my axles might be a touch too long (I have read many people having this issue) so I trimmed off 1/8". This made no difference to my axle offset. I then measured the inner part of the bearing with where it is suppose to seat on the axle housing (see pics). It seems there is where my length difference is. The inner part of the bearing is much larger then the seating area. My question is did I get the wrong bearing? Any other thoughts on this issue? I am a little confused on how to proceed.
thanks
thanks
