Inside door # is: 124377L108089; Under hood Vin# is 10B K228 Body Paint
ST 67-12437 LOS 4887
TR 760Z
W 2MG
5 BY
It appears to be a 350 Cid engine w/ 350 Transmission. I'd like to know what is actually supposed to be in this car from the factory, color & rooftop: vinal or hard. I'll get the engine, trans & rear end codes later. Thanks for everthing; I'm glad to be a part of this family.
Sinkit67 "Lets get started".
124377L108089 =
12437 = Chevrolet Camaro 8cyl 2dr. Sport Coupe
7 = 1967
L = Los Angeles Assembly plant
108089 = Production sequence number. Starts at 100001. Your's is the 8089th Camaro ever built.
10B = October, second week
K228 = Los Angeles work order code
ST 67-12437 = 1967 Camaro 2dr. Sport Coupe, standard interior
LOS = Los Angeles assembly plant
4887 = Fisher body sequence number. Doesn't corespond unit production number.
TR 760Z = Standard black buckets (I don't know what the Z means
I can't help you with the rest. Someone else will probably be able to tell you what they mean.
Bryan Shook
Favorite Quote - Some people have shrinks. Some people have their garage.
www.geocities.com/motorcity/speedway/6673
this is the info i found @ http://holisticpage.com/camaro/parts/67trim.htm
12437 - Sport Coupe, standard interior
12467 - Convertible, standard interior
12637 - Sport Coupe, custom interior
12667 - Convertible, custom interior
Note: In 1967 the trim tag did not identify a 6 or 8 cylinder engine in this spot, only the interior style with the code 4 or 6 as the third digit. The VIN did show a 3 or 4 as the third digit indicating 6 or 8 cylinder. 1967 was the only year the interior style was coded like this.
Z - Bucket seats
there should be some letter on the same line after the TR 760Z that will tell you the exterior color.
W 2MG
5 BY
Group 1
W - tinted windshield
Group 2
M - Powerglide transmission
G - center console
Group 5
Y - deluxe seat belts
B - appearance group including bumper guards, floor mats, and door edge guards
To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg
forgot this:
Group 4
P - correct code for SS 350
N - 396/325hP
K - 396/375 L78
L - 302 Z28
F - remote mirror
If there was no designation in Group 4 (as your tag shows), the car was either a 327 V-8 or six-cylinder model.
you may want to post this in the "tag team" section to get a better response if you wish to know more.
Could you look the Trim tag again and post the TRim/PaiNT line again (TR 760Z ?? PNT),
this shoud tell the upper and lower color, or if it had vinyl top and which color.
Also take a look at the tire sticker in the glove compartment to see the tire size since it may help determine which engine the car had. Look the rear end it is a 10 or 12 bolt, the car has traction bar, if so is it round or square, from what side of the firewall does the speedo cable penetrates. All this things may help determine exactly what engine did your car had.
Hope this helps.
[This message has been edited by Moris (edited 01-21-2000).]
