1 - 2 of 2 Posts
I would like to change out the dash pad on my 67 Camaro RS, I am looking for some assistence on this activity. How hard is this ?
RANZ, I HAVE HAD THE DASH PAD OUT OF MY 67 RS SEVERAL TIMES, THERE ARE ABOUT 6 OR 8 SPEED NUTS ON THE BACK SIDE UNDER THE DASH THAT HOLD IT IN. YOU WILL FIRST HAVE TO REMOVE BOTH A-PILLAR MOULDINGS, REMOVE THE GLOVE BOX, REMOVE THE GAUGE CLUSTER(SPEEDO AND FUEL GAUGE CARRIER) THIS IS ABOUT THE ONLY WAY YOU CAN ACCESS ALL SPEED NUTS. GOOD LUCK
1 - 2 of 2 Posts
