1 - 10 of 10 Posts
hello my 67 camaro has a 327 with a 4 bbl carb and a 350 turbo trans, it also has an electric fuel pump, the issue is i like the power and everything but its a serious gas guggler, i literally think im getting 8 miles per gallon going down hill, outside the tank adjacent to the wheel well there is an electric fuel pump, that always hums when i turn the key, is there a chance that the thing is pumping way to much gas, i know this may sound like a stupid question but are there electric fuel pumps that are more fuel thrifty? or should i go back to a manual pump all toghther, i dont know the pros and cons rather i do know electric fuel pumps started out to prevent stalling and flooding etc, i just dont know how cost effective they are..
with all this being said my gaol really would be around the 13-15 mpg which i think is fessiable i even thought about replacing the manifold back to 1 that fits a 2bbl but than again i think it would drive me insane if i couldnt pass some of the people that come up and "rev" their engine especially when they are in some foreign honda or something..
You have a little thingy called a needle and seat inside your carb.As long as the supplied fuel pressure does not overcome the needle and seat..the fuel pump swap will not affect mpg.I would steer clear of a 2 barrel.You would gain more hp and mileage with a spread bore quadrajet.The primarys are small and the secondarys are huge.Drive her easy..never roll open the secondarys until you want to take it to the ricer crowd.
"...especially when they are in some foreign honda or something..":)LOL - Amen to that. I will be changing out to 4bbl probably this winter. I have all the parts just haven't had the time.
Banned
My stock 350SS w/ an M-20, 3.31 posi- and 25.5" tall tires would get like 17 mpg on the hwy when new back then if I stayed out of it.
Get in her and I never checked!
I had my Q-Jets top rear butterfly's set to where I could sneak up on 65 mph, maybe 70, before they started to suck open.
pdq67
First thing you should do is find out how much fuel pressure that pump is pushing. Chances are though, if you don't smell gas, it's not over powering the needle/seat. Like it has been suggested, the spread bore style carb is the way to go for a street car and especially one that wants more MPG. The small primaries are great, especially if you don't get into the secodaries(rather large). I run a 350 with a Powerglide and 4.10's and I get around 10-12mpg, depending on how I run her and that's with a square bore style carb. I am switching over to a Q-Jet though to get the best of both worlds. The Q-Jet can be a formidable street fighter carb. It can even be a nice drag strip carb. Just ask the Nostalgia class guys.
1- connect vaccum gauge and adjust carb to pull most vaccum, stock cam should have 18-24hg, also, check for vaccum leaks, check trans vac line coming off intake and runs to back of trans, is steel line but has rubber connectors.
2.make sure distributors vac advance is working, may be hooked up to wrong port on carb.
3.check your plugs and wires - are all plugs firing? test compression to make sure your engine is healthy and tunable
4 is your speed-o -meter correct. if not your odometer may be registering more miles than you are really going. thus throwing off your mpg's
could be many many things -
I agree with the vacuum advance. Make sure it is working the way it should. At cruise, the vacuum advance will definately help with gas mileage.
what is your rear end ratio?
What RPM does your engine turn at 60mph?
1 - 10 of 10 Posts
