1 - 15 of 15 Posts
Is there a vendor out there that will sell just the front carpet piece for a 67 Camaro? I need just the front in black, but every catalog I look at sells the set only (front/back), or a one piece application.
Nope.
Don
Discussion Starter · #4 ·
I think you have to get the complete set. . . .it will match instead of old and new. Its like shoes and socks, they to come in "pairs"
Rats. I'm trying to keep this Camaro as original as I can, keeping as much of its original pieces as possible. The back carpet is still in very good condition. The front is very worn at the drivers side, hence the reason for replacement.
Discussion Starter · #6 ·
Close, I have the rear. Replaced the front in my Firebird last year for the same reason.
Interesting...one has to wonder what previous owners were doing in the back seat that wore out the back carpet instead of the front!
He’s saying he has new rear he hasn’t used because he only replaced the front but had buy both the front and rear as a set.
Discussion Starter · #8 ·
Yea, I saw that now. Still wonder how many 50+ old people now that were created in the back of our 1st gen Camaro's0:)0:)
Reactions: 69Z28
Should try that in a VW. D'oh! >:)
Discussion Starter · #11 ·
I did...my first car, a 61 Beetle, with a 1959 36 HP engine. I was about 80 pounds less. Rear seat was removed, and rear was carpeted.
Reactions: 69Z28
Discussion Starter · #13 ·
Never did...maybe I'll get lucky while cruising through some local swap meets. Otherwise, I'll end up buying the entire set.
The point of the set from a satisfaction and marketing point of view is that they match. You can call AAC direct 800.352.8216 (Toll Free) or 256.236.1118 (Local in AL) and see if they have a scratch and dent set that didn't pass inspection for some reason, and they are willing to sell you just the front. But I would think they just match the orphan front up with new rear sibling.
Another option is to buy the new two piece set and only install the front and put the back in storage or use it in the trunk.
In general I think once you put the new next to the old you will see the old really is worn and there is no law that says you have to get rid of the original factory carpet, just store it along with any other original parts you need to replace for the next caretaker.
Discussion Starter · #15 ·
Good logic.
However, I just made a move from one house to another. In going up in the attic, I found that I was a huge hoarder of automotive parts. Many of these were just as you described doing; put away parts for the next caretaker. It was then that I simply tossed the stuff into the pile that has its next address of the dump.
Before I get hammered, I'll explain that the majority of these parts are not vintage usable original OEM parts. They are not going into the attic of my new house.
I'm guilty of treating this Camaro as if it were 5 to 10 years old; replace just the worn item with new, and keep any and all original parts intact. Its in really good shape, and gets driven weekly.
1 - 15 of 15 Posts
