I have a 67 that was a 3 spd in the flr. got a console now going 2004r got console wiring.So now I need to get n/s. I think there is no place to plug in plug on the harness. Will I have to remove plug and wire in seperate.?
Al - Waterloo, Iowa
I'm in the process now with my 67. I bought the Shiftworks overdrive shifter. It comes with
the neutral safety switch and back up lights switch. Yes you will have to splice into your wiring
harness for the n/s switch. Purple wire from ignition switch. Or you can continue to run without
the switch.
ok,I have the same,I know I will have to splice, trying to fig if I have to splice both purple wire to ignition and starter.
I have two heavy purple wires from console harness,I guessing both spice into ignition wire? I think iam getting this.
I'm moving this tread from the website issues section to electrical.
