Need some help guys. Keep in mind that I am by no means an electrical expert. I just finished removing the in-dash factory fuel and installed a repo factory tach. I also put in a new repo circuit board. All the lights work, however the tach doesn't. It appears to have power coming to it because when I turn the key on the needle will jump a little.
I need to know if there are any external wiring (independent of the circuit board) I need to run to make this thing work. I noticed that the tach as two termials coming off the back. Should these be used? I am running an MSD 6AL, MSD dist and coil.
Thanks,
Gary
Gary
1967 Camaro SS/RS 396-375 4sp.
http://community.webshots.com/user/amike95
Thanks,
Gary
Gary
