Rick,
Thanks for the pics! I've got a 67 RS convertible with a 327, vortec heads, HE286 cam, and a 600 CFM Edelbrock carb. I've acquired a TBI setup off of a 89 454 truck and I'm in the process getting all the misc adapters, plumbing and wiring to go on. My biggest problem will be the fuel system. The in tank fuel pump would be my preferred setup.
Looking at the pictures you emailed me. I see you transferred the whole 88 IROC fuel assy and part of the IROC tank over to the 67's. That seems like a lot of work!
I was thinking about mounting a pump on my existing 67 tank pickup and adding a return line and wires to it. There must be a good reason why I can't do that. Maybe torque relief on the pump, or it won't fit through the hole in the tank?
You’re right about having a professional weld the tank. I had a friend who burned down his house just welding near the tank!
Thanks again
Dave
http://www.toomanyprojects.org:2000/camaro/efi/EFI_Project.html
