I have read past posts and I am still a little confused.
My horns don't work.
1) At first I could hear the clicking at the relay but it doesn't click anymore.
2) I put 12 volts to both horns from the battery and they both are operational.
3) I have checked wiring on horn relay and it is as pictured on other posts plus I haven't played with it since it was working so I assume it is wired correctly.
4) I checked power at the black lead in the Horn relay it has power all the time.
5) The green wire never has power.
Could it be the horn relay itself, I have replaced it once not too long ago, but have since had the car rust proofed.
Help!
I gounded out the black lead and no power to the Green wire. By the way I did this with the ignition off. So does this mean it is a bad horn relay?
Thanks undee, I replaced, acutally my son replaced horn relay everything works, This threw me for a loop because I replaced it less than a year ago and didn't think the relay would be the cause!
