67 Manual Steering Box - Rebuild
11359 Views 8 Replies 4 Participants Last post by  67 RSS
Greetings all,
Looking for a well written / documented "How To" regarding the rebuilding of a 67 Manual Steering Box. Looked through the archives and discovered information about rebuild kits and several places that will rebuild your old steering box but not really anything on a "do it yourself" effort.
Currently counting nickels and dimes (not the most fun way to do a restoration) and thought I'd give the rebuilding of the steering box myself some consideration.
Thanks in advance for your help!
Chevrolet Unit repair manual. It gives rebuild procedures for gearboxes, compressors, alternators, etc. Only about 120 pages or so.
The one I'm using I picked up off of ebay for my 78 Chevy truck years ago. It covers all 78 Chevrolets. I am currently rebuilding the power steering gearbox for my 68 Camaro using this manual. So far it is still relevant considering 10 years difference. I too am trying to save a bit here and there on my Camaro build by refurbishing when I can.
There is a section for the manual gearbox as well. If you'd like I could try scan and email. Send a pm with an email. Experience tells me the pictures are going to be big files. So it could be a bit slow sending.
After entering into this power steering gearbox rebuild, I now know why they are so expensive to buy.
Brett in Boise
This might work :).
http://www.highperformancepontiac.com/tech/hppp_1008_steering_box_rebuild/index.html
I just finished my Power box on my '72...$39 for a kit. I broke the large piston ring and had to reuse the old one..other than that a good project. Last one I sent out was $300+..didn't want to ship it and wait this time...spring is here...always wondered how they worked and after rebuilding it I still wonder :D.
No more leaks and the pump quieted down..guess the fluid leak helped get air in the pump?
I cut and paste to make a word file and printed each picture..
http://www.fourwheeler.com/techarticles/drivetrain/129_0801_saginaw_steering_box_rebuild/index.html
http://www.pirate4x4.com/forum/showthread.php?t=570869
Great links! Better than the manual. I knew I shoulda counted threads. oops.
Thanks.
THNX ALL!
Team Camaro ROCKS!
Thanks.
If you are referring to the upper plug adjustment..snug up to remove play in thrust asm (22ft-lb seems excessive- I didn't do that) and back off 1/2". Found a post by JimL82 that provides GM instructions below.
To adjust sector lash- I used my fingers to turn the input shaft and adjust lash until I felt it drag (David Pozzi suggest this in one of his posts) you can find via search as well. Couldn't get the in-lb torque wrench technique to provide much help..(These two topics were not accurately addressed in the internet links I posted initially- not sure about the manual box settings)
http://www.camaros.net/forums/showthread.php?t=129288&highlight=steering+adjust
And back on topic ;) ..check out Jim Shea's (JimL82) website...there is a manual GM box overhaul file and lash setting as well. Likely same GM info as suggested above.
http://jimshea.corvettefaq.com/?p=603
http://www.camaros.net/forums/showthread.php?t=171285
My worm gear bearings are pitted/corroded and out of round. They are bad enough that I can't tell which are the silver chromed ones vs black chromed ones aside from a couple of them. Also the piston worm bearing grooves are pitted/galled. Talking with Lee powersteering I could order a set of worm bearings but I would have to know what oversize I want.
I may be over technical about the worm gear bearing issue but I think it is important. I wonder what constitutes a "reman" gearbox at the parts store? The price at NAPA is $140 plus core. Which is $110 cheaper than going through Lee for a standard rebuild. I'd hate to have the steering lock up at 110 mph at the drag strip.......
Ah sounds like it had water in it...maybe new std brgs with a new worm and piston is needed?
http://www.larescorp.com/index.html
Lares rebuilt one for me..I was pleased with quality..looks like they have these in stock..I think David Pozzi posted the p/ns for the various boxes in one of the threads I stumbled on...or maybe Jim..
1965-69 All 1274 202
1965-69 16:1 Fast ratio (order # 200 coupler) 1276 200
1965-69 New 16:1 Fast ratio (order # 200 coupler) 276 200
One on epay with BIN of $159...http://cgi.ebay.com/ebaymotors/1964...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Not sure where NAPA gets their boxes...
