1 - 16 of 16 Posts
I was poking around in my owner’s manual the other day and it says the correct bulb for the parking/turn signals is a 1034A. I have had 1157A's in there forever. I went to the local AC-Delco parts store and asked about 1034A's. The guy looked on his computer and said no one in the city stocks 1034A's. He asked what kind of car I had and after I told him, I could tell from his body language that I had been 'dismissed' and that no other helpful information was forthcoming. I'll probably try a NAPA place later this week, since they are usually willing to look things up the old fashioned way - in the manual. In the meantime, what is everyone else using? I haven't had a problem with the 1157A's over the years, but I don't want to use a bulb that is not the right one for the application. Did the 1157A supersede the 1034A? Thoughts? Opinions?
Mark...
Some info...
Kev
Original equipment bulbs on most pre-'72 cars was as follows:
1034: dual-filament park/turn and brake tail. Clear bulb for use with red rear or amber front lens.
1034A or 1034NA: dual-filament park/turn. Amber bulb for use with clear front lens.
1141 or 1073: single-filament bulb. Reversing/backup lights (and single-function—brake-only, turn-only—lights not frequently found on old Mopars).
In the early '70s, the 1034 was replaced by the 1157, the 1073/1141 by the 1156. These 1150-series bulbs put out the same amount of light, but draw slightly more current and last quite a bit longer. When changing from 1034s to 1157s, often it was (and is) necessary to replace the turn signal flasher, because the original would flash too fast if used with 1157s. Nowtimes, it's difficult to find a flasher calibrated for 1034s.
So, what to use for upgrade bulbs? Well first, here's what NOT to use: 2057s! People sometimes assume that because it's a higher number, it's a brighter bulb. No. The difference between 1157 and 2057 is in the "minor" (dim parking or tail) filament. On the 2057, the dim filament produces 2 candlepower. On the 1157, the dim filament produces 3 candlepower. The difference doesn't sound like much, but it's very large as a percentage. Both 1157 and 2057 produce 32 candlepower from the bright (brake or turn) filament.
Though they are spendy, the best bulb you can use in place of 1157 is called P3496. It draws the same amount of current as 1157, but is much more efficient. It produces 43 candlepower on the bright (brake or turn) filament, and 3.5 candlepower on the dim (tail or parking) filament. It also has a nickel-plated base that is much more corrosion resistant than the plain brass base of an 1157.
The best replacement for 1156, 1141 and 1073 in all applications *except* reversing/backup lights is P3497. It produces 45 candlepower. (Yes, the 6 and the 7 in P3496 and P3497 are reversed from the 6 and the 7 in 1156 and 1157 relative to how many filaments the bulb has. This is not a typo.) The P3496 and P3497 bulbs have a life span about double that of an 1157.
The best bulb for use in backup/reverse lights is a P796. It is a 35W halogen bulb that produces 62 candlepower, or about double the light of an 1156 and about triple the light of an 1141. The extra wattage is minor (35W vs. 28W, the wires and lenses will not notice or care) and the filament is in the right place. Neither of these compliments can be said of those 50W halogen backup bulbs you see in the parts stores! 50W is wayy too much current draw (100% overload!) for the stock wiring and switch, they produce way too much heat for safety near plastic lenses, and the filament's in the wrong place so the reflector doesn't work correctly with them. The P796s work great, and you finally get to see where you're going when backing at night.
Amber bulbs are a special case. The amber coating "steals" some of the light, so the output is lower. The bright filament inside an 1157A or 1157NA produces 32 candlepower, but what comes through the amber coating is 24 candlepower. Unfortunately, there's no amber equivalent of P3496 for use in park/turn lights that have clear lenses. The next best thing is 2357A or 2357NA, which draws the same current as an 1157 and produces 30 candlepower despite the amber coating. 2357NA (or 2357A), as well as their non-amber 2357 counterparts, are considerably less expensive than P3496, but they lack P3496's anti-corrosion nickel-plated base, and they also lack P3496's Krypton gas fill, so they tend to blacken sooner than other bulbs if used in "bright" mode for prolonged periods (e.g. using a 2357 in brake lamp service). The 2357NA or 2357A works fine in front park/turn service because turn signal service is short and intermittent, which limits bulb blackening and makes overall bulb life acceptable.
Be careful when buying any of these bulbs. A lot of the major parts outlets are switching from name-brand bulbs worth buying to 3rd-world crapola not worth its blister pack. One company makes quality 3496s and 3497s, for example, that is Stanley. GE and Sylvania usually supply Stanley-made 3400-series bulbs (read the bulb base) but both marketers have been flirting with Chinese look al ikes lately.
Discussion Starter · #3 ·
Kevin, thanks for the excellent response! This one gets printed out and stuck in a notebook for future reference, that's for sure. Lately I've been trying to replace the bulbs in everything from the glove box to the licenese plate lamp with the correct bulbs instead of the "Hey, look it fits!" approach I took years ago.
More Info...
Kev
1968 CHEVROLET Camaro
High & low beam headlamp
H6024
H6024ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6024XV XtraVision Halogen Upgrade: 3x brighter; 2x the life
H6024CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
1157
Stop light
1157
License plate
67
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194NA
Rear sidemarker
194NA
Ash tray
1445
Glove box
1895
Map light
562
Dome light
211-2
Step/Courtesy light
631
Trunk/Cargo area
1003
1003LL Long Life Upgrade: Up to twice the life of the standard lamp
Under hood light
93
Instrument-general
1445
1816
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Brake warning
1816
Automatic transmission indicator
1445
Clock
194
Directional signal indicator
194
Radio dial
1893
More Info...
Kev
1967 CHEVROLET Camaro
H6024
Parking light
1157
Front turn signal
1157A
Rear turn signal
1157
Tail light
1157
Stop light
1157
License plate
1155
Back up light
1156
Ash tray
1445
Glove box
1895
Map light
562
Dome light
211-2
Step/Courtesy light
212-2
631
90
Trunk/Cargo area
1003
Under hood light
93
Instrument-general
1895
194
Brake warning
194
1895
Clock
1895
1895
Radio dial
1893
More Info..
Kev
1969 CHEVROLET Camaro
H6024
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1157
Tail light
1157
Stop light
1157
License plate
67
Back up light
1156
Front sidemarker
194
Rear sidemarker
194
Ash tray
1445
Glove box
1895
Map light
563
Dome light
211-2
Step/Courtesy light
631
Trunk/Cargo area
1003
Under hood light
93
Instrument-general
1445
168
194
Hi-beam indicator
194
Brake warning
194
1445
Clock
168
194
Radio dial
1893
Discussion Starter · #10 ·
Mark...
Some info...
Kev
Went to Advance Auto Parts today to get me some of these awesome bulbs. The guy at the counter never heard of P796's or 796's and didn't find them in the computer. They had all the others out on the rack, so I snapped up a few pair of each. Althought they are Sylvania brand bulbs, the bases all state MADE IN TAIWAN. Oh well. I'll try a NAPA store for the P796's. I really like the idea of a brighter backup light. Only problem is all of the NAPA stores in this area are a minimum of 10 miles away from where I live or work.
Discussion Starter · #11 ·
Mark...
The best bulb for use in backup/reverse lights is a P796. It is a 35W halogen bulb that produces 62 candlepower, or about double the light of an 1156 and about triple the light of an 1141. The extra wattage is minor (35W vs. 28W, the wires and lenses will not notice or care) and the filament is in the right place. Neither of these compliments can be said of those 50W halogen backup bulbs you see in the parts stores! 50W is way too much current draw (100% overload!) for the stock wiring and switch, they produce way too much heat for safety near plastic lenses, and the filament's in the wrong place so the reflector doesn't work correctly with them. The P796s work great, and you finally get to see where you're going when backing at night.
* * UPDATE * *
I found a parts place that had some of the Wagner P796 bulbs IN STOCK yesterday, so I snapped up a set. They are quite a bit more expensive than the 1156's - like about $7.50 a bulb, but they sure are a lot brighter! I hope they last a good long time.
I know that this thread was a long time ago, and I must say that I am very impressed. It was kinda technical for checking out all the numbers and the parts of the car, but it gave me new ideas in order to really check it more closely. Car parts and accessories like Turn Signal Switch are very vital and more vigorous to find and to replace, so this is a good reference in order to really check out the choices you have. Thanks for the posts, it is indeed a good help for all of us!
1 - 16 of 16 Posts
