where do the relays and switches mount for the frt conversion kit. i would guess they mount to the radiator support somewhere? does anyone have photos as to where they mount?
Should be in the AIM on page 427 if the kit is a OEM reproduction.
the relays and circuit breaker mount to a bracket that bolts under the left front fender behind the radiator support just forward of where the fender support bolts to the fender. the bracket and relays are hidden up under the fender. the opening limit switches bolt to the radiator support, the closing limit switches bolt to the headlight/motor housing
67freak do you have any photos? thanks
i do have the aim but it does not tell you where to put them, it is only a illustration and does not have any detailed wording as where this stuff bolts onto. the aim is limited. if anyone has any other book that is better than the aim please let me know. thanks
67freak, where does the rubber grommet go for the frt park lamp housings and the rear back up lamps, i would greatly appreciate any photos you can provide
