1 - 2 of 2 Posts
We are having trouble making our 67 Camero RS headlights work. Our problem is when you turn the key switch on the headlight doors open with the headlight switch off. When you turn the light switch on the headlight doors close. We have replaced the diode harness at the key switch. We have replaced all 4 limit switches. We have replaced the horn relay. We have replaced the headlight motors. The limit switches appear to be wired correctly. The blue and brown wire to the dash harness is wired correctly. Have not replaced relays, not sure if they are wired correctly. Everything appears to work but opposite of what it should. Help!
1 - 2 of 2 Posts
