The other thing to consider is that some manufacturer details of the fan blades sometimes changed without the part number changing. For instance, you can have two identical fan blades except for the number of rivets per blade and/or the shape of the rivet heads, but (based on the car build date and the AIM) they should have the same part number. On Chevelles at certain plants they went back and forth from one blade style to another. So on those cars at least, it was not a case that one version was used in all cases up to a certain date, and the other version was used in all cases after that date. And I have NOS examples of every rivet combination in GM boxes that all have the
same part number, even though the rivet attachment of the blades are different. So I tend to think it was a case of more than one supplier providing parts with the same GM part number, or a case of a supplier that had more than one plant and their procedures were not standardized at all the plants. But that is just my speculation ...
So, since 67 (and older) blades are not numbered, in my opinion you are better off to speak in terms of the size of the center hub bolt pattern, the number of rivets per blade, the shape of the rivet heads, and the shape of the blade (whether it is or is not indented along the edge of and at the outer end of the rivet attaching area), rather than trying to ID a 67 blade by the part number. The number (since it is not on it) does not matter as long as you have the "correct looking version" of the blade.
My unrestored survivor 67 SS 350 with A/C was LA built, so if your car is Norwood built then this info may or may not be helpful to you (again, possible different suppliers or different plants of the same supplier). But the original fan blade on my car (with 11B cowl tag) has the small center hub hole with 3" bolt pattern, with the indentation in each blade (along the edge of and at the outer end of the rivet area), with 4 rivets per blade, and the rivet heads are flat.
The clutch is an Eaton. It has no engraving on the face. Attached are pics, including the length of the mounting shaft, which is 1-5/8" from the BACK side of the fan blade to the FRONT side of the pulley. As you can see, the shaft has a constant diameter (it is not tapered or swedged like some of the other brand fan clutches and some of the later Eatons were).
Also see the link in my signature below for some pics of the the car.
If searching for a correct IH and OG radiator (if you don't have one), be careful as a major current day Harrison radiator builder says that the IH and OF radiators they produce are correct for A/C Camaro's. Bull. The IH and OG radiators were used for ALL '67, '68, and '69 Camaros with A/C. Steve
I encountered that issue too. One of the few things that has been changed on my car is the radiator. The original reportedly leaked and they put a generic parts house radiator in it. :sad: After months of trying to find an original, in 2009 I gave up and ordered a repop Harrison from HBC. It was wrong in more ways than just the code on the right-side tank! The mounting bracket on the left side was also wrong and had the hole for the lower bolt in the wrong place, and the overflow hose connection pointed in the wrong direction. I called and complained, and was told that I did not know what I was talking about, and that my unrestored survivor car must have a repro core support in it and that that was the problem!!
But several weeks later I got an email from them apologizing and saying I was right, with pics attached of a correct 68 350/AC radiator that they had located. They said they were going to dismantle that unit and make all the pieces to do a correct repro of the IH/OG radiator. However, they did not offer to send me a correct one and take the wrong one back! And based on the current description on the website, looks like they did not make the correct OG tank either.
I also asked if I could buy the remnants of the 68 radiator when they were done copying it, so I could reassemble it with a new core and put it in my car. They never replied.
So if any of you have a 3010181 radiator (UK tag code, and IH / OG tank codes) for a 67 350 or 327 with powerglide and A/C that you would sell, please let me know!! It makes me very ill every time I open the hood and see that repop radiator in there!!
Thanks! Jeff
