Putting my 67 350 back together. Does it matter which way the oil filter adapter goes back on? Looks like it can go 180 degrees around and still bolt up.
Thanks!
The concave part should be down if I remember correctly...
One piece of advise: when you screw the center stud in (that recieves the new style filter) don't turn it all the way in. You want to have a solid 2 turns on the new style filter and if you turn the stud all the way in, that won't happen. Use the loctite provided.
1967 was the last year for the old canister oil filter. The adapter has a built in bypass valve and it doesn’t matter what position the bypass valve is installed.
