1 - 2 of 2 Posts
Can anyone tell me if the seat belts that came in 67 Camaro's are the same as 67 Chevelle's? I saved the belts out of my 67 chevelle when I was a teenager and found them recently. Still in good shape. Kevin
68SS 396/375 L-78
Kevin, the buckles are the same, retractors are diff, lengths might be longer for the chevelle, but only by an inch or so. Manufacturer will probably not be the same. Camaros were Irvin for standard, Chevelles were DAAL or Robbins.
One caveat: The buckle style changed between 66 and 67 and they are not compatible. You have to be sure you have the newer style. Do you have pics?
If you get some proper Camaro retrators, the chevelle ones can be used. Shortened (or not if you don't mind the extra and remove labels, if you care about it. I've retroed Chevelle belts for Camaros.
Luck, Kevin
1 - 2 of 2 Posts
