As part of my power brake booster upgrade I've purchased the small block pre-bent brake vacuum tube that all of the Camaro parts suppliers list as common 67-69. I also purchased the stand off bracket that supports the hose that attaches under the aft-inboard valve cover bolt. It seems as there is no way these components work together (metal tube does not come anywhere close to the correct length angle to line up with that bracket hole).
The plug wire support stand off bracket for 67 is directly in the way of any reasonable position of the tube... (68 has a hole in the middle of it and the tube would work perfect with that - but I want to keep the engine dress all 67 factory correct for an L30/M20 car MK code no smog).
What is the correct assembly supposed to be? For me running the rubber hose all the way from the brake booster to an intake fitting is unacceptable - no way they did that in 67 out of the factory. I've found lots of pics online of laughable positioning of that tube, so it is clear that I'm not the first to be unaware of how it came from the factory, but I must be in the minority of those who care beyond it just functioning... I want it as close to replicating factory as I can.
