1 - 1 of 1 Posts
What manufacture sells a bolt-in tubular transmission crossmember for a TH-350 in a 67 Camaro.
I would prefer a 4130, but mild steel would work if thats all thats out there.
I see they have mild steel TH400 tubular crossmembers on Ebay, but no TH350 style.
I actually use a TH400 behind a 540 BBC. But I use the small block frame motor mounts, which sets the engine back a bit.....so my stock TH350 crossmember lines up a little better with the factory subframe holes. (redrilled the stock TH350 crossmember mounting holes off a bit to fit).
Would like to go tubular to save a little weight and cleaner look.
Thanks for any help,:D
Mike
1 - 1 of 1 Posts
