Hello Guy's,
I ran into a issue wiring the the headlights on my 67, I have a aftermarket core support and it does not seem to have the Voltage regulator mounting holes, No matter how I position it nothing seams to line up with the 3 holes in the regulator or let's it lay flat, I have the Factory assembly manual which shows it above the horn relay and angled with the wire connection toward the fender.
WOULD ANYONE HAVE A PHOTO OF THERE"S IN THE STOCK LOCATION??
PLEASE HELP!!
Correct location is above the horn relay. You might have to drill holes to secure it.
Not sure if your trying to put everything to stock locations but I made a bracket and mounted my horn relay and voltage regulator inside the fender then made covers that mount to the inner fender, fender, and radiator support and it looks real clean. I also ran the wires to the fuse box between the fender and inner fender. I think wires look like crap so I go through alot to try to hide them
Thanks Guys for the feedback! I'm trying to put it back in the stock location, I don't mind drilling a few holes if I know it correct.
Any Photos out there on a Stock Core Support??
