While cleaning out my basement I found two NOS mirrors in the box with bracket and screw in original packaging. The boxes are labeled #3914753 LH Mirror (10-DCA-7) and #3914754 RH Mirror (2-DCA-7).
I'm not convinced the proper mirror is in the proper box, and since I sold my 67, 68 and 69 Camaros a long time ago, and I don't have a reliable way to check this information. I'm hoping you can help. (Looking around online only makes me more confused.)
The mirrors are mirror images of each other and the joint where the swivel holds the mirror base is off center, so one is definitely LH and one is definitely RH. They are positioned so that the etching on the glass is at the bottom and is upside-down.
I don't plan on keeping these, but I'd like to make sure the correct mirror is in the correct box.
I labeled the pictures because I figured I have a 50-50 chance of getting it right. Any help solving this is greatly appreciated.
https://www.amazon.com/clouddrive/share?s=blqMhav5QWYiQIl1VcLfNQ
https://www.amazon.com/clouddrive/share?s=xSeMcmYITGEgxMtLLAuUrg
Thanks Lynn. I'm halfway there.
The rest of the problem is that only the boxes are labeled. There is no Part Number on the mirrors themselves. I'm trying to figure out which mirror goes in which box. One mirror is the mirror-opposite of the other, but which one is driver's mirror? I tried to describe this in the linked images.
I know this response is late but I have two mirrors I'm selling on eBay and was also wondering if I had them identified correctly.
It seems logical that you have the longer part of the mirror on the outside but I think you have them upside down. The lower part will contact the door. So, I'm gonna say you have the labels reversed. Don't you think?
Larry
