Hi there,
I have a 68 camaro with factory 4 season a/c.
Sadly at some stage someone has removed the wiring harness from the fan speed switch and selector control assembly (low blow switch).
Luckely i found the factory harness.
The way i see it, i cant really come through the glove box (duct work issues), removing trim plate etc does not give access to behind control assembly and i dont really want to remove instrument gauges to get behind control assembly.
Im leaning towards removing am/fm radio and muti plex set up. Looks like a job though. A/c duct work to deal with behind am/fm radio.
or
Removing dash pad??? not sure on access from there though.
Any suggestions would definately make things a little easier as i may have missed something.
Cheers
or
Cheers
