with brakes on,and lights working, i put my right hand turn signal on and my left brake light goes off, any ideas will help, thanks in advance
Re: 68 camaro brake light trouble
Did you check any of the things that were suggested two days ago?
the light socket sparks a bit when i install it back in, the right and left signals work as they are put on, the brake lights work on their own when applied, something thing is cancelling out the left brake light when the right hand signal is engaged, where should i be looking, the signal switch in the steering column.
