I just got a new tumbler for the ignition my question is how do you take the old out, the whole switch is on the bench all I need is to know how does the old 1 comes off the switch.
Put the ignition switch in the ACC position. Insert a wire (paper clip or small drill bit) into the small hole in the face of the lock cylinder. Push in on the wire to depress the plunger. Continue turning the key until the cylinder can be removed from the switch.
'69 RS Camaro
355 5-speed 4.11
