I am trying to replace my front passenger side interfender wheel well and I would like to know if it can be removed without removing the fender. The car has AC.
Thanks, Doug
Re: 68 camaro interfender wheel well removal
never done with car together but many times doing body work. I doubt you'll be able to without removing the fender unless you are houdini
The only way I have done so is without the radiator support in place. To remove the radiator support, you need to push the top in towards the engine w/o the radiator or fan in place. You will go through just about as much effort as removing the fender, yet there is less likely a chance of ruining the paint on the fender and door.
The body shop that painted my car put them in with the fenders on. There was no motor in the car though.
