1 - 10 of 10 Posts
My good friend has a 68 Camaro 327-275HP with a powerglide. We have done some minor performance hop up's like intake, headers, exhaust, and igniton. I was wonder if it should light the tires up in a straight line from a dead stop, because it doesnt, and i was wondering if it should then i need to tune it somemore like in the carb area im thinking. (Q- Jet)
thanks
a quad-jet will give you high end performance-not much out of the hole. If you do switch to a roch 4b the car may bog down out of the hole since it cant create the rpm's-the a/t and the stock cam are working against you.
Drag racers use a modified 2 speed version of a powerglide but the guts are very differant. The only hope you have in my opinion for acieving your goal[its not cheap either] is a lower set of gears in the back. Still its not practical for that model. I have a 327 210 horse car. I appreaciate the car for what it is & spend the sweat keeping it clean & straight- it's a unrestored #3 car. [Most people think their cars are #2's] --sell the car buy yourself any v8 with a stick--smoke the cars at every light.
Discussion Starter · #4 ·
Thanks, yea it does do pretty good a high r's but grunts and strains from a start. At one time i had it do it but guess it was luck. Thanks for your help.
69 Chevelle SS 396 L-34
Discussion Starter · #5 ·
I adjusted the air valve for the sec. and it helped from what he tells me but i havent seen for my self. It leaves nice right turn rubber and i got it to leave some and then 2nd gear getting the right rear started in the grass on the side of the road
Thanks again for ya'lls help.!!!
My '68 is the 327/210 horse version and would bake the tires indefinately with the original PG trans and a 3.08 non-posi rear. Of course, this was with stock mono-leaf springs that were past their time. Once I put on a 4 barrell the problem was horrible. I don't know why your combo isn't lighting them up. Once I put on multileafs and traction bars, the problem stopped.
If you do want better accelleration though, I have since swapped to a TH350 and had the rear rebuilt with a 3.73 gear and a posi. That is some fun! I would recommend it.
G
I have a 4 Barrel Holly Double pumper with Vac advance, I also have a TH350 But not yet sure of what I have on the rear end sence I have not made it to the back yet, but here are the numbers taken off the Axel 3969340NF GM17 Can anyone tell me what these mean!, and will I have the same slugish problem off the start as the other guy above did? (Although Im not racing it) Im treating the car like it should be!
G
I have a 4 Barrel Holly Double pumper with Vac advance, I also have a TH350 But not yet sure of what I have on the rear end sence I have not made it to the back yet, but here are the numbers taken off the Axel 3969340NF GM17 Can anyone tell me what these mean!, and will I have the same slugish problem off the start as the other guy above did? (Although Im not racing it) Im treating the car like it should be! Please help me!~
1 - 10 of 10 Posts
