Hi there,
As the subject highlights my camaro originally had the F70x14 tyre size. I believe the metric conversion to be 215/70/R14?
Any information on size metric or OEM will be appreciated.
Cheers.
Darren, you are correct, the closest match to the F70 is the 215/70 in metric. That tire will fit on either a 14x6 or 14x7 rim. With a 14x6 rim, you can run 205s or even 195s (but they look a little thin on the rim). 14" tires in that size are starting to get scarce, I run BFGs.
Hi there,
Thanks for the information.
I'm running the 215/70/R14.
Just need to source a retailer in these neck of the woods that offers the redline tyre.
Thanks Kevin.
Cheers:yes:
